Am I Diagnosing This Misfire Correctly?
A little history....The long block has just 9500 miles since new. The coil pack is the older style. It was a "used" purchase. The spark plugs and wires were new. The fuel injectors were used but I had them cleaned and flowed. I had the gas tank flushed, a new fuel pump and sock installed. The gas filter was replaced. The truck intake was cleaned. Everything ran great except during it's only summer. The truck stalls on hot days and I'm pretty sure it's because the Granatelli MAF sensor is throwing very sporadic rich codes. A new stock truck MAF has been ordered. I'm thinking the rich mixture has finally fouled those two plugs and my older coil pack can't compensate.
and fuel injector delivery (imbalance) both of which
could make one hole go lean.
I've seen people say that the misfire cylinder number
is not reliable, can be off from the real culprit position.
So if you can't find a cause, may try swapping to the
left and right and look for the reported misfire to move,
no matter what cylinder it says it's about. Keep your
eye on the thing that's being swapped, and look for
whether it made a difference - expected position or not.
I went ahead and purchased the upgraded truck coils with the heat sinks. It's an upgrade I've wanted to do for awhile. I had some rewards points through AutoZone so I bought their highest quality lifetime plug wires and some TR5 plugs. Didn't help. Replaced the Granatelli MAF with a stock truck. Did nothing but lose power. Guess those things work...LOL. Still chasing those two weak code throwing cylinders. Will check the intake gasket with starting fluid and change the two fuel injectors if need be. When I had the injectors cleaned 18 months ago, the shop said they had to run two of the injectors through the cleaning process twice to get them to work. Maybe those are the culprits.
What do those 2 plugs look like compared to the others. Post a picture if you can.
If the plugs all look the same and you have 2 weak cylinders, it would generally indicate a mechanical problem. I would check compression on all cylinders. If that doesn't indicate a problem, I would move the injectors to different cylinders to see if the weak cylinders move.
Also pull your valve cover check for broken valve springs or bent push rods
The GM scheme has a blowoff regulator on the return
and the pump just gives 'er all it's got, has to provide
a pressure surplus. If you are pump limited at idle then
you're hosed (heh) at the big end. Most GMs (and all
4th gen F-body donors) had non-manifold-referenced
fuel pressure and if you are putting vacuum (manifold
pressure) to the regulator then you need to fundamentally
change your IFR table, which as-stock models a variation
in fuel shot with manifold vacuum; a manifold referenced
regulator eliminates that trend (and it's not a bad thing,
can help consistency, but you need to model it right).
There are spreadsheets out there that can help you
with that.
with that.
Just for reference, the Ford uses a return system. I went with an older Silverado intake that has a built-in regulator (new) with a factory return set up.
