FAST Intakes, Nick Williams Throttle Bodies, & Plug N Play Crossover Hoses @ Hinson
FAST LS1,2,3,&7 LSXR 92mm & 102mm Intakes are all ON SALE. Pair it with everything you need to make it a Plug N Play setup like, throttle bodies, intakes, crossover hose kits, fuel rails, and the port seals to complete your setup! Hinson Motorsports can offer you Plug N Play crossover and feed hoses for your Corvette in your choice of colors. Check out all the options in the links below. We are the only company that offers a complete plug n play feed and crossover hose kit for your FAST fuel rail setup on your Corvette. All pre-assembled and ready to install in your choice of colored fitting and hoses.
FAST LSXR 92mm & 102mm Intake Manifolds Your Choice On Sale <- CLICK HERE FOR PRICING & INFO
Don't Forget your Port Seals!!!!
LS1 & LS2 Style FAST Port Seals <- CLICK HERE FOR PRICING & INFO
LS3 Style FAST Port Seals <- CLICK HERE FOR PRICING & INFO
LS7 FAST Intake Comes With Port Seals
Nick WIlliams 102mm Throttle Body in Black <- CLICK HERE FOR PRICING & INFO
Nick Williams 102mm Throttle Body DBW <- CLICK HERE FOR PRICING & INFO
FAST Billet Fuel Rails Red (Also Available In Black) <- CLICK HERE FOR PRICING & INFO
OEM Fuel Rails LS7 <- CLICK HERE FOR PRICING & INFO
Hinson Motorsports C5 C6 & Z06 "Plug N Play" Feed & Crossover Line Kits (Choices of Colors of Hose & Fittings) <- CLICK HERE FOR PRICING & INFO
Hinson Motorsports GTO "Plug N Play" Feed & Crossover Line Kits (Choices of Colors of Hose & Fittings) <- CLICK HERE FOR PRICING & INFO
Hinson Motorsports F-Body "Plug N Play" Feed & Crossover Line Kits (Choices of Colors of Hose & Fittings) <- CLICK HERE FOR PRICING & INFO
Hinson Motorsports 2010+ Camaro "Plug N Play" Feed & Crossover Line Kits (Choices of Colors of Hose & Fittings) <- CLICK HERE FOR PRICING & INFO
That depends on what TB and which intake you need for your setup. If you go to our site you will see they are all organized appropriately and you can add them to the cart for totals. Anything over $350 ships free to the lower 48 states.
http://www.hinsonsupercars.com/s-532...stem.aspx#Fuel Rails & Lines
Add the items you wish to purchase and it will add it up for you. If your order is over $350 shipping is free to the lower 48.
