Super Vic and FAST 4150 - TB spacer or no TB spacer?
I have a Super Victor and 4150 throttle body on my car with a 1" spacing and a nitrous plate. I was told to run as must of a spacer as I have room for. I was told adding the spacer increase plenum volume, which will increase performance. I have no tests without the spacer to see if it changes the performance.
Cant say for sure. I ran the spacer from the beginning. I actually used it to prevent from having to drill and tap a spot on the intake for the brake booster vacuum line. The spacer i bought has a 3/8" NPT hole tapped into it. I ran the brake booster to that and the PCV to the large NPT fitting on the fast 4150.
