Sheet Metal Intake
Old Jul 7, 2015 | 09:28 PM
Zoomin's Avatar
Default Sheet Metal Intake
I like the look of this intake, but I have no idea if it makes any sense to put this on a street car or not. This will be going on an LS1 with heads and cam to be determined. It has a 102mm opening so would be using a larger throttle body. I'm looking for power under the curve, lots of low end torque.
Anyone have experience with these?
Old Jul 7, 2015 | 09:34 PM
drew408's Avatar
All I know is they run $350 or less shipped and they aren't good for boost.
That intake would definetly not be better for low end tq and more power under the curve than a stock ls1 intake.
It's a rip off of a high $$$ sheet metal intake and would be best suited to a bad *** set of heads and a radical cam.
Old Jul 7, 2015 | 09:35 PM
drew408's Avatar
If u do a search,you'll see where some1 has cracked one under boost pressure.
Old Jul 8, 2015 | 12:55 AM
alowerlevel's Avatar
Should be all you need to know.....
https://ls1tech.com/forums/generatio...ed-intake.html
https://ls1tech.com/forums/generatio...s-garbage.html
https://ls1tech.com/forums/general-l...aud-aware.html
Old Jul 8, 2015 | 05:14 AM
HCI2000SS's Avatar
I'd just do a Fast intake or stay with what you got
