Anyone Using These Coils?
Old Jul 24, 2015 | 08:33 AM
2JZFC's Avatar
Default Anyone Using These Coils?
Having some ignition issues and suspect I might need a set of coils. Running some tests to confirm but looking ahead for replacements. Looking for feedback from anyone using these.
http://www.ebay.com/itm/GM-4-8L-5-3L-6-0L-Square-Style-Ignition-Coils-kit-V8-set-of-8-Free-Grease-Pack/171743999593?_trksid=p2045573.c100033.m2042&_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D29981%26meid%3D0e46ed68c7744b4d8f8532afb42f968d%26pid%3D100033%26rk%3D3%26rkt%3D4%26sd%3D180746509591
Old Jul 24, 2015 | 09:16 AM
redbird555's Avatar
they would work fine however you would need new coil harnesses and brackets since those will be different than the ls1 ones you have now
Old Jul 24, 2015 | 10:06 AM
thunderstruck507's Avatar
For about $70-100 you should be able to get a set of coils, brackets, and harnesses from either the classifieds here or a salvage yard.
It's very rare coils are the issue. Most common would be cracked plugs or burned wires. Next up would be a damaged coil harness or engine harness. The only time I've seen an ls coil go bad was when a friend running MegaSquirt turned up the dwell and literally melted the coil.
Old Jul 24, 2015 | 01:19 PM
2JZFC's Avatar
Those are the style coils I am currently using.
By coincidence, I am running MS and have the dwell at 4.5. Is that too high for these early truck coils?
Old Jul 24, 2015 | 01:27 PM
https://ls1tech.com/forums/generatio...ime-coils.html
