AC compressor blew up
I looked online and from what I found the cost of going to a shop and getting the compressor replaced is like 700-1000 which seems ridiculous to me. I looked online and it appears to be a 200-300 dollar part... which sucks. My question is could I replace it myself and then bring it somewhere to have the system evacuated of moisture, air, and other contaminents, as well as filled with oil and refrigerant? Are there any other components that will need to be replaced? It's just sitting in the garage right now with a hole in the compressor. Also has anyone else seen anything like this or have any idea what would have caused it? Thanks
the compressor is easy to get off... two 15mm bolts on top and 2 15mm bolts on bottom and one 13mm bolt holding the lines on at the rear of the compressor
forgot to mention that most places you buy a compressor at (including my work) will only have a warranty if you get the orifice tube and receiver dryer at the same time ..
PS even the replacement ac delco compressors are made overseas now, so get the best deal going and be done with it. I did
(you may have to give it a whack or two)
and yes the 13mm bolt on back is easier to get off when you can move the compressor forward and out.
