stupid AC tensioner pulley
Old Jun 7, 2004 | 10:42 AM
TIMMEH's Avatar
Default stupid AC tensioner pulley
Is squealing like a rat in heat. I spray it down with silicone lubricant which temporarily remedies the squealing. However I'm sure the bearings in it are failing. Soooooo...is it easy to swap?
Old Jun 7, 2004 | 07:21 PM
WILWAXU's Avatar
Can't be that hard.. if tackled from the bottom.
Old Jun 7, 2004 | 08:01 PM
redbandit98's Avatar
no its super easy,just jack it up so you can get at it from the bottom. although the tensioner itself is a hard to find item and is not cheap..i think 45 bucks or something.
Old Jun 7, 2004 | 08:20 PM
CamaroB4C's Avatar
You can still get it from the top pretty easy. You are going to need a star bit. I got my tensioner from the dealer at cost for like 40 bucks. I think it is around 55-60 orginally for them. I had the same problem about a month and 1/2 ago.
Old Jun 7, 2004 | 10:32 PM
98B4CZ28's Avatar
I think mine started squealing recently also. Does it just squeal when you turn on the A/C? I was thinking it might be the compressor but it still blows cold.
Old Jun 8, 2004 | 09:41 AM
TIMMEH's Avatar
You can get you a can of spray lubricant and target each pulley individually until the squealing stops. That will tell you where it's coming from. In my case BOTH the tensioner and the AC compressor needed to be replaced. The clutch in my compressor was going out.
Replacing the tensioner...omg that was a 5 minute swap. I can't believe I was remotely concerned. All you need is a 13 mm socket. One bolt... Oh, btw...you can't purchase the pulley separate from the tensioner anymore. At least I couldn't find a place that would...so I bought it from GM. $91 for the entire tensioner/pulley. Oh well...no more squeaky!
Old Jun 8, 2004 | 03:12 PM
LethalV6's Avatar
mine started making noise out at the Texasmile event. After checking with the dealer @ $90 for the entire part I decided to take the pulley off and pack it with bearing grease (inside the sealer caps) and re-install....hasnt made a noise since. I would highly recommend trying this before spending the cash at the dealer.
just my .02
