Jet Hot LT problem........here it comes....
Old Jun 7, 2004 | 10:33 PM
99ssleeper's Avatar
Default Jet Hot LT problem........here it comes....
The driver's side collector is about 1/4" away from the floor of the car.
I know others have had this problem....how did you fix it?
Anyone ever get a replacement header from Jet Hot? If so, how did that work out...what did you have to do?
Old Jun 7, 2004 | 11:30 PM
popocamaro2's Avatar
we stuck some heater hose in between the floor pan and pipe if the banging is your problem
Old Jun 7, 2004 | 11:55 PM
LS1LT1's Avatar
Smile
Yes, heater hose or a BFH (big f*ckin hammer ) against the floorpan.
Old Jun 8, 2004 | 12:46 AM
jrp's Avatar
jrp
SN95 Director
hmm, mine cleared everything fine, even with the collector flanges.
Old Jun 8, 2004 | 08:35 AM
AGRV8D's Avatar
I haave a loud banging on mine that i noticed, all i have to do is some heater hose,hmm
Old Jun 8, 2004 | 10:18 AM
2001CamaroGuy's Avatar
1/4" sounds about right......
you can either have headers that hang low to the ground and clear the body, or you can have headers that band the body and clear over speed bumps....which do you want? I personally would take the "bangs the body" every time
I installed poly motor and trans mounts to help limit my banging. It helped but could still hit on hard launches or when the clutch chattered. Now I have the motor in with plate mounts so movement should not be a problem .
Old Jun 8, 2004 | 11:24 AM
KALEL's Avatar
yea ive had it also...i put the hose in between the car and header but it kept falling out..anyone have this problem???
Old Jun 8, 2004 | 12:17 PM
ONGRNGO's Avatar
I have no banging problems with mine, I had to knotch the K-Member a little and thats all.
Dan
Old Jun 8, 2004 | 03:14 PM
99ssleeper's Avatar
The driver's side collector is an inch higher off the ground than the passenger side. All I need is another half inch of clearance between the collecter and the floorpan on the driver's side.
My passenger side header doesnt hang any lower than my tranny pan or driveshaft loop and I have never scraped them. The passenger side fits perfect...why cant the driver's side hang in the same spot?
Or is everyone else not as picky as me?
