Electric water pump and 102mm tb... spacer for clearance?
If this topic has been discussed (most likely) then I apologize in advance but I did a search and couldn't for the life of me find the info I needed.
To get clearance between the NW102tb and meziere pump on my setup I've grinded to the limits of what I'm willing to take off and everything is snug. Now, I intend on milling the heads for increased compression which will probably require the manifold be milled to suit. To get extra clearance between the parts I was thinking of getting some kind of throttle body spacer.
My questions are,
1. Will a throttle body spacer adversely affect performance?
2. Has anyone done this before for this purpose?
I can get a completely custom spacer milled at work for free... but I don't want to go out of my way to do this if it's going to screw around with the performance of the car. I am interested in a spacer purely for clearance.
Thanks for the help.
My questions are,
That's MISTER MODERATOR
Welcome to LS1tech!
https://ls1tech.com/forums/generatio...g-threads.html
I really doubt it.
I've never heard of it but if anybody has, post up!
I really doubt it.
Thanks for the welcome! And the response, the link is helpful too.
I've done some more searching and there appears to be a spacer available, however it looks like it has all these fins etc to swirl the air as it goes in. Looks like a gimmick to me and for the price i'd rather just mill a no frills plate myself.
I hope so. If I proceed with the planned mods this is going to be my only option. I'll be sure to post up my results and some pics if it works!
