TSP Rumbler X System Now Complete!!
LS1TECH & Trucks Sponsor
All the hardware (including hangers) you need is included. We put it on a car with Pacesetter LT's last night, complete bolt-on. Dyno numbers didn't turn out right because since he had stock exhaust and we did the baseline, we put in a 3500 TCI converter. Expect about the same gains as you would from long tubes and a TSP Rumbler. The X system just gives it a deeper/throatier sound. It was a stock internal car, and although it is of course fairly loud, even at WOT it was a clean roar without rasp ![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
-Matt-
-Matt-
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic3451_2.gif)
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Originally Posted by TWINK
I am definetley intersted in one
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
-Matt-
__________________
There's no existing hole for them. You can drill a hole easily, or weld it if you would rather.
-Matt-
-Matt-
__________________
This system will not work with body mounted torque arms
However, the BMR or others that are tranny mounted should have no problems.
-Matt-
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
-Matt-
__________________
Did the system "line-up" with the pacesetters (new style) with no modifications? Earlier it was mentioned that these were designed for Jet-Hot or Hooker LTs so I didn't think it would work without modifying it for the Pacesetter's.
Great system! Thanks!
They fit with no extra bending, stretching, welding, etc. They will clear without any work on the floorboard. Or for those who want extra clearance (lowered vehicles) and to tuck the system up a bit further, you can modify the floorboard (not visible inside the cabin) for additional clearance.
-Matt-
-Matt-
__________________
