Which starter?
Old Sep 23, 2015 | 03:31 PM
Hawk312's Avatar
Default Which starter?
I want to replace the starter in my LS1 with a stock(ish) unit. I have long tube headers. After a search, I see many of you suggesting the "truck" starter which is better because of the longer bolt? Is this a direct fit, and what "truck?"
Thanks
Old Sep 24, 2015 | 06:29 AM
Zach-R's Avatar
I'm not 100% on the years but it is a direct fit and you will need the truck starter bolts.
Old Sep 24, 2015 | 12:00 PM
JT2000WS6's Avatar
Many starters you buy now will have the new bracket design with two long bolts anyway. If you google the truck style you can clearly see the diffence in bracket designs which will help you pick out a new one. It is a direct fit however it can be a little more difficult to wedge up in there due to the bracket.
Old Sep 25, 2015 | 01:15 AM
Spade's Avatar
I purchased a starter from Summit a while back, seems to be a well built piece. Of coarse it did not come with the new style bolts, just fyi.
Old Sep 26, 2015 | 04:16 AM
NineZeroFive's Avatar
Fyi I had to do a little grinding for clearance but it was worth it to have the longer second bolt.
Mine is an 02 camaro a4.
Old Sep 27, 2015 | 06:20 PM
1BAD98LS1's Avatar
The truck starter is the way to go especially if you have a little more compression than stock, I got mine from a junkyard and haven't had any issues. For easier installation you may want to cut off the alignment tab on side the block, it was only there for the factory to use on the assembly line and it won't hurt the integrity of the block or anything. I'm not sure of the years etc but I asked for one off an 05 1500 Silverado and it works great.
Old Sep 27, 2015 | 09:47 PM
Majestic9C1's Avatar
I have a Delco Remy truck starter on mine...
Old Sep 29, 2015 | 09:10 AM
MonmouthCtyLS7's Avatar
I grabbed one off of Ebay for my Old Fbody and it worked flawlessly.
