Alternator Replacement
Old Oct 27, 2015 | 06:09 PM
Project Bird's Avatar
Default Alternator Replacement
So I blew the hose off of the bottom of the power steering reservoir and you guessed it, fluid went everywhere including in my alternator. It has been acting weird, sometimes it will act normal maybe a little bit of overcharging and then it will be a constant 18V on my gauge with the interior lights becoming super bright. I'm not driving it for long periods of time right now because I don't want to destroy this battery but I also want to see if it will dry out and go back to normal but will replace it this weekend if I need to.
Anyway I heard the parts store alternators for these cars suck but I also don't want to spend 400 bucks on a new alternator. Anyone have any suggestions?
Old Oct 27, 2015 | 06:49 PM
ragtopz28's Avatar
I just went through the same "what to do"...reman's suck, powermaster expensive and mixed reviews...I got a recommendation on a reputable local shop to go through/rehab mine, cost 40 bucks
Old Oct 27, 2015 | 07:19 PM
Amazon.com: ACDelco 335-1075 Professional Alternator: Automotive Amazon.com: ACDelco 335-1075 Professional Alternator: Automotive
Looks like this may be the way to go. delco and 50 bucks cheaper than parts store remans.
Old Oct 28, 2015 | 09:13 AM
black535xi's Avatar
Thank you for this. Been trying to figure out which one i want to buy, bc I've heard all the horror stories of the parts stores
Now, if i could just find a good write up on how to get the darn thing out of there
Old Oct 28, 2015 | 09:36 AM
DANOZ28's Avatar
if you do a thread search you'll see several people like the gm truck alt (aprox $135 & more amps) or i went with mechman aprox $200 sold at texas speed.
Old Oct 28, 2015 | 09:40 AM
lemons12's Avatar
I got a used DR-44 (truck alternator) I'd sell.
90$ shipped
Old Oct 28, 2015 | 10:36 AM
black535xi's Avatar
Truck alt a direct replacement?
Old Oct 28, 2015 | 10:58 AM
ragtopz28's Avatar
It's easy (if you have articulating sockets and two really long extensions for the back bolt, lol).
There are a couple of Youtube vids, but I could not get my hand back there with an end wrench.
Old Oct 28, 2015 | 11:07 AM
black535xi's Avatar
I found a thread with some good pics. Looks like getting at it from under the car isn't a real big deal, and I've got plenty of extensions and swivels
Old Oct 28, 2015 | 05:21 PM
X-ray's Avatar
Yep. I have a feeling you already found this thread, but just in case...
https://ls1tech.com/forums/generatio...failure-s.html
Old Oct 28, 2015 | 05:45 PM
s7ven's Avatar
Just make sure you disconnect the battery and also the single wire connector on top the alternator before removing the mounting bolts....ended up breaking mine.
Old Oct 28, 2015 | 07:14 PM
ragtopz28's Avatar
Good tip here...that is one tiny wire!
Old Oct 28, 2015 | 09:44 PM
black535xi's Avatar
Yep, that's the one...
And I've read that the little wire is super fragile... and I'm not exactly known for finesse
Old Oct 29, 2015 | 07:06 AM
lemons12's Avatar
Yes. And fixes charging issues many have.
Old Oct 29, 2015 | 07:41 AM
black535xi's Avatar
I never had any charging issues, but my car has burned up a couple fuel pump relays, and had some strange intermittent stuff this year. I just bought the thing in April, so i just assumed there's probably some kind of upgraded fuel pump without the necessary wiring to accompany it... now I'm wondering if the alt was on its way out and had some voltage spikes or something to eat those relays?
Old Oct 29, 2015 | 10:06 AM
lemons12's Avatar
Possibly, electrical is no fun at all.
Most people upgrade to a Walbro pump. I'm running dual 450s. The most common is a single 255 for lower power guys. They also have a 340.
Old Oct 29, 2015 | 12:15 PM
black535xi's Avatar
It's weird bc it'll just cut out going down the road, and at one point even died and had to be towed home. Couple hundred $ worth of diagnostic labor and we tried a relay just to see and problem solved. I bought this car from a forum member and he had a whole spreadsheet of the upgraded parts, but wasn't sure on the fuel pump... it's like 415 rwhp and he had time slips to back it up plus the n2o, so i doubt it's a stock pump with all the other high dollar stuff that's on it
Old Oct 29, 2015 | 03:17 PM
lemons12's Avatar
My buddy had a stock fuel pump in his car for a little while.....
451 LSX block, mast intake, powerglide, Fab9, full suspension, etc etc etc...
I wouldn't be 100% on that. LOL
Old Oct 29, 2015 | 03:47 PM
black535xi's Avatar
Well, I'll find out whenever i get into this turbo build. Probably gonna go with lonnies twin setup
BUT... first thing i gotta do is get the alternator replaced so it can move under its own power ��
