Ls1 both banks glowing cats help
Old Nov 10, 2015 | 08:08 AM
Patsy57's Avatar
Default Ls1 both banks glowing cats help
Hey all so I recently replaced the head gasket on the driver side. After getting everything all set and installed back in the car, the car runs the same but both cats on each bank are glowing red.
Any idea why this is? It didn't happen before. I checked all hoses and no vac leak. The driver side header was off at one point and it's all back on now. Could it be the cat connection between the y pipe and the beast is loose?
Wouldn't this only impact one bank?
Any help is appreciated!
Old Nov 10, 2015 | 08:28 AM
Mean87SS's Avatar
Probably plugged...
Old Nov 10, 2015 | 08:36 AM
Mappinsj's Avatar
They may be clogged!
Old Nov 10, 2015 | 09:14 AM
Patsy57's Avatar
What the cats? Or?
Old Nov 10, 2015 | 09:16 PM
DietCoke's Avatar
cats are done for.
Old Nov 11, 2015 | 03:35 PM
Old Geezer's Avatar
Flooding them w/ raw gas.....
Old Nov 11, 2015 | 06:39 PM
Patsy57's Avatar
Would changing the pcv can which created more vac adjust the fueling table to create this issue?
Old Nov 11, 2015 | 07:00 PM
joecar's Avatar
Check if all plugs and all injectors are firing.
