stock harmonic balancer question
Old Nov 12, 2015 | 07:17 AM
mikesimpalass's Avatar
Default stock harmonic balancer question
I've been shopping for an underdrive harmonic balancer, and it's between the fluid damper and the ati, I'm leaning towards ati. I spin my engine up too a max of 6500, but usually I shift at 6200. some people claim that a fluid damper actually does a better job cancelling vibrations below 6000 rpm. but the General consensus is, any high rpm applications should use the ati.
any input?
also,I was curious, how good is a stock balancer at cancelling engine vibrations?
Old Nov 12, 2015 | 08:31 AM
DANOZ28's Avatar
several posters will tell you the ati is the best but it costs alot. i felt any sfi approved balancer is an upgrade over stock , most are about half the cost. just my one cent.
Old Nov 13, 2015 | 01:52 AM
axe murderer's Avatar
ATIs are the best but IIRC they also don't recommend more than a 10% underdrive.
Every car in NASCAR uses an ATI.
Sometimes you can find a cosmetic blem on eBay, last time I talked to ATI they said that's the only place they're sold
