What injectors for Fast 102/102, cam only???
Ok guys I have FAST 102/102 intake and tb combo, also have a 224/224 cam, headers, air intake and full exhaust.. What injectors do u recommend? Stock? Or upgrade? Also what injectors work with the FAST 102? My stock ones don't seem to seat right and from what I'm seeing is I might need adapters or bigger orings??
If you're stock injectors work with that setup then you need a new tuner :-). If you switch them out go ls3, about the same money or cheaper with more headroom. Fic has an adapter kit with spacers and adapters for like $100-$120.
