Bad Waterpump or Air in system?
I started the car up with the cap off and the system full to bleed the system. I squeezed the upper and lower hoses many times to try to work out any air. The temperature rose pretty quick. Right around 210 degrees, the steam vent return hose in the radiator started spitting out coolant. Before my buddy went to turn off the car at about 218 degrees, the level in the radiator rose very quickly and started to overflow. I heard a nasty gurgling/bubbling sound as well when this happened. We shut the car off and the level dropped. The lower hose to the thermostat is still cold.
I tried about a dozen times but the same thing keeps happening.
- Could the water pump be defective?
- It's probably unlikely the thermostat just went bad at this moment.
- Possible air in the system??
I loosened the bolts to the thermostat and coolant was there. It started leaking all around it.
I read a bunch of forums and the only new information that I didn't already do was to disconnect the TB coolant hose when filling and keep filling until water comes out of the hose. I just did this fill procedure but it's late so I'll fire it up tomorrow to see if it makes a difference.
Any help is greatly appreciated!!
Thanks for the tip. I want to try that but I put new Mishimoto hoses on that are super tight and a pain in the a$$ to get on and off. I'll definitly do that on my other car when I do a antifreeze change.
I jacked the nose of the car up pretty high and I also unbolted the steam vent tube on the front of both heads. I filled up the radiator until fluid was starting to come out of the two holes in the heads. I'm thinking I just had huge air pockets in the heads and they were heating up way too fast before the rest of the system. Car holds a steady 187 now. Took 15 minutes for all the bubbles to stop in the radiator. Nice even flow of fluid from the steam vent return now.
