Power Steering Cooling Question
https://www.texas-speed.com/p-1553-d...ler-01-04.aspx
and radiator with oil cooler and trans cooler is one more cooler in the other tank.
If I understood what you wrote correctly.
What you're looking at is not really a cooler, but a heat exchanger. The goal there is to try and stabilize the heat between the oil and the coolant. Since PS oil can get pretty hot, that will add an extra thermal load to your radiator. If the car can handle it, fine. If not, then use a separate air/oil cooler.
The bottom line is, yeah, you can use that cooler for your PS.
