oil pan differences
Old Dec 30, 2015 | 02:26 PM
travperkins's Avatar
Default oil pan differences
I am wondering what are the differences in oil pan sizes between a 99 LS truck oil pan and the 99-02 LS Camaro oil pan? I am putting a 99 LS in a 1954 chev 210 and some people are saying that you have to use a camero pan. is there a huge difference in dimensions or are some people splitting hairs?
Old Dec 30, 2015 | 02:30 PM
the more digging I do, this seem a little odd. im wondering if the info I was given wasn't BS.......... im new to the LS department so forgive me if this is a dumb question
SS69LS1's Avatar
This should help you
http://www.improvedracing.com/tech/L...dimensions.php
Old Dec 30, 2015 | 02:31 PM
SS69LS1's Avatar
The truck pan hangs down quite a bit further than the Fbody pan. Ive never swapped a truck, so I can help you there. Scott
Old Dec 30, 2015 | 02:41 PM
First thing that seems weird to me is that the camaro is a 5.7........ Dumb question is the camaro 5.7 an LS based engine??? Seems like all the LS crap you hear about is 4.8 5.3 and 6.0 you never much about the 5.7
Old Dec 30, 2015 | 02:50 PM
SS69LS1's Avatar
yes- LS1 = 5.7L The 4.8/5.3/6.0 are mostly iron block truck motors; 6.0 LS2 aluminum block can be found in 05-07 vette/05-06 GTO/trailblazer SS/05-06 SSR pickup. There are other variants, such as aluminum block 5.3 w/243 heads. Try a seach or read thru the stickies for some good info on all this.
Old Dec 30, 2015 | 07:03 PM
Well thank you so much for the info, you have been very helpful!!!
