1999 F Body LS1 motor mount bolt sizes.. 10mm and 15mm?
Bolts into the block, and bolts into the frame... what socket/wrench size are the heads? Is the motor side 10mm and the frame side 15mm?
I want to make sure I have all of the tools I need before I start.
I just put new mounts in my car and the bolts for the block were 13mm and the bolts for the frame were 15mm. This on a 2000 TA. The heat shield on the driver's side had 10mm nuts that were screwed to the bolts (bolts have a small stud in the head) that mount to the block. So you will need 13mm deep well sockets.
