FAST 92 reassembly issue
Old Feb 24, 2016 | 04:49 PM
ws6_bandit's Avatar
Default FAST 92 reassembly issue
So my motor blew a year or so ago and im just getting around to putting it back together. The intake was full of oil and metal. Bought a new seal kit from FAST and tore it apart. Im assuming the gap in the pics will disappear when the intake is torqued on the car? I just want to double check before I put it on the car. Thanks.
Attached Thumbnails FAST 92 reassembly issue-tmp_32750-20160224_163616-800x450-256761357.jpg   FAST 92 reassembly issue-tmp_32750-20160224_163648-800x450-937927821.jpg   FAST 92 reassembly issue-tmp_32750-20160224_163640_001-800x450-97191003.jpg
Old Feb 24, 2016 | 06:18 PM
Mongoose350's Avatar
All of the seals being new, I'm sure is the reason. It will likely create a true seal as you torque it and crush them into place.
Old Feb 24, 2016 | 06:27 PM
elephantrider's Avatar
is there a gasket between the upper and lower hat ? i know there
is for the runners, of course, but wasn't sure on the hat seal.
Old Feb 24, 2016 | 07:22 PM
ws6_bandit's Avatar
I used rtv where the runners meet the lower piece. But i used the actual FAST gasket to run the perimeter and over the top of the runners.
Old Jan 4, 2017 | 09:57 PM
draggz28's Avatar
Had a question since you already did this yourself I recently bought a 92mm and when I opened it up it had no gaskets anywhere so I purchased he rope gasket for the top and bottom shell. My question is the runners that are screwed in to the bottom shell also use the rope gasket? Or is it just screwed on?
