BUILD THREAD "My son's first T/A - Bracket Car"
Old Oct 10, 2017 | 10:53 AM
  #141
ragtopz28's Avatar
Simulated 1/4 pull...
Old Oct 13, 2017 | 01:34 PM
  #142
ragtopz28's Avatar
Only got in two test pulls (track crowded and break/oil downs). Time slips attached.
Needs less fuel jet and more timing and she'll be in the 9's on the .62 pill.
Only slowed down a few tenths on motor.
Oh and converter is borderline too loose.
File Type: pdf
Old Oct 29, 2017 | 06:27 PM
  #143
ragtopz28's Avatar
Did the John Deere Hygard swap today...should help on the initial "flash" and on the big end. Will log it and report back soon.
Old Nov 5, 2017 | 07:39 AM
  #144
ragtopz28's Avatar
HyGard did nothing...Needs a new converter. She flashes straight to 6000 on the hit and blows the tires and the 60' is .3 off. Should be in the 1.3x range. Still traps 131mph so 9's are there just needs a little more $$ thrown at her.
Old Nov 12, 2017 | 06:49 PM
  #145
ragtopz28's Avatar
More free weight reduction...#40 today
Old Nov 12, 2017 | 08:08 PM
  #146
Jtm2085's Avatar
What was removed?
Old Nov 13, 2017 | 05:45 AM
  #147
ragtopz28's Avatar
Originally Posted by Jtm2085
What was removed?
Both door crash bars, rear bumper support, and hardware.
Old Nov 13, 2017 | 07:34 AM
  #148
Jtm2085's Avatar
Nice, I need to remove my door bars
Old Nov 13, 2017 | 07:48 AM
  #149
ragtopz28's Avatar
It's kinda a pain but worth it @ #20. You do have to drill a hole (doorknob hole size) in the end of the door to slide it out. It will not come out otherwise. That assembly must be done before the door skin is put on.
Old Nov 13, 2017 | 09:50 AM
  #150
Jtm2085's Avatar
I didn't realize they were that heavy!
Old Nov 13, 2017 | 11:07 AM
  #151
ragtopz28's Avatar
Weight "sticky" says #6 but the two together with bolts was #18+
Old Dec 4, 2017 | 09:42 AM
  #152
ragtopz28's Avatar
Buffed, polished, and waxed. Came out great. Should pick up 1 mph, ha!
Still looking for the 9's this Sunday at a private track rental....
Attached Thumbnails BUILD THREAD "My son's first T/A - Bracket Car"-buffed-12-2-17.jpg
Old Dec 13, 2017 | 02:43 PM
  #153
ragtopz28's Avatar
Sooo close...converter is killing me...Time to order up one!
Attached Thumbnails BUILD THREAD "My son's first T/A - Bracket Car"-img_20171211_091602787.jpg   BUILD THREAD "My son's first T/A - Bracket Car"-25075108_1650033215052845_1355613498576843678_o.jpg
Old Dec 13, 2017 | 02:53 PM
  #154
SOOOO close is right! Won't take much to do 9's. We're talking DETAILS here! lol
Old Dec 13, 2017 | 03:00 PM
  #155
ragtopz28's Avatar
Needs a nitrous converter. This is on a FTI N/A Hard Hit 4000 not intended for nitrous at all. It flashed straight to 6,000 on the hit and is slipping 16-18% on the big end.
Old Dec 13, 2017 | 03:09 PM
  #156
Oh OK! Sound like you have a handle on this! Best of luck!
Old Jan 13, 2018 | 06:53 AM
  #157
Big bird55's Avatar
What did you have to do to get the 15x10s on the back with the stock rear? I have a lq4 ta I'm looking at doing 243s or an ls3 top end. Do you think with a 243you would be around the same with the little bit more compression. Seeing this build gives me high hopes
Old Jan 17, 2018 | 07:39 PM
  #158
ragtopz28's Avatar
I cut off the bump stops. They cleared fine with the 10 bolt and now the S60. The cathedral vs. rectangular argument continues....If it's not an all out drag car, I think some ported 243's would make more power most everywhere. I went LS3's because I already had them and a cam for the rectangular ports. GL with yours.
Old Jan 19, 2018 | 05:09 AM
  #159
Big bird55's Avatar
Sadly the argument is still going. You are just one of the first I have found that has a combo extremely close to what I am doing mince why I asked
Did you roll the rears as well?
Old Jan 19, 2018 | 06:38 AM
  #160
ragtopz28's Avatar
It's the tire size and rim offset that start to cause clearance issues. Just make sure you get the "F-body fitment" ones. My tires are 275/50-15 (26") so plenty of room. A 275/60-15 (28") should still clear without rolling.
