LS2 into a Fbody?
Old Apr 2, 2016 | 05:33 PM
wannafbody's Avatar
Default LS2 into a Fbody?
Does anyone make a swap kit for putting a LS2 or LS3 in a Fbody?
Old Apr 2, 2016 | 06:04 PM
Paul Bell's Avatar
That's MISTER MODERATOR
A LS2 is a genIII so you'll need knock and cam sensor harness extensions:
http://texas-speed.com/p-2247-racetr...t-harness.aspx
http://texas-speed.com/p-2248-racetr...t-harness.aspx
A LS3 is a genIV so you'll need more PLUS changing the crank reluctor:
http://texas-speed.com/p-4758-texas-...-vehicles.aspx
Old Apr 2, 2016 | 08:51 PM
wannafbody's Avatar
Would the LS1 headers fit the LS2?
Old Apr 2, 2016 | 08:58 PM
01CamaroSSTx's Avatar
Look at the exhaust ports on the LS1 and LS2 cylinder heads, I believe they are both circle port so I don't see why not.
Old Apr 2, 2016 | 09:38 PM
ULTIMATEORANGESS's Avatar
Smile
yes they will. if you have heads theyll also swap over fine.
worthwhile upgrade imo.
Old Apr 2, 2016 | 09:56 PM
wannafbody's Avatar
Thanks, I wasn't sure if there was a difference in block height between the 2 engines.
Old Apr 2, 2016 | 11:27 PM
Crf450r420's Avatar
Motor bolts right in. Finishing my LS3 install now. I'm running a Holley Dominator to control the motor and DBW though.
Old May 13, 2016 | 01:25 PM
spaz1's Avatar
Cranks are different reluctor wheels and crank sensor, but early ls2 have the right ones, or you can swap it out...
 Michael S. Palmer
Old May 13, 2016 | 03:23 PM
farmington's Avatar
Or u can buy the Lingenfelter plug in box to use the newer crank and not change the reluctor
Old May 13, 2016 | 03:25 PM
spaz1's Avatar
I heard they don't work that good.
It's not hard to change the reluctor ring.
Old May 13, 2016 | 04:04 PM
dailydriver's Avatar
I was considering a GM crate LS3 until I heard the mixed reviews on the Lingenfelter unit's reliability/functionality.
If one is not an engine builder (or have those skills/facilites), or does not have friends in an engine shop, changing out the reluctor becomes a BIG $$$ nightmare, on top of an already expensive engine/ancillaries.
