Question about ORY banging fix
I'm planning on wrapping in the appropriate "tape" then adding a cut section of 3" rad hose followed by more "tape" Just want to make sure I don't use the wrong stuff and have it melt.
Thx in advance..
The poly mount fix is a good solution, but some people have been very unhappy with the added roughness transferred to the chassis.
The tape is there both to make sure it stays on and to keep it from melting. Not sure if the Y gets hot enough but I dont want to smell burning rubber. I just want to know if muffler tape and header tape are the same thing or if they are different??
If you do that, do you need to bother with the poly tranny mount?
About header tape vs. muffler tape. The muffler tape is cheaper and has a level of heat resistance. The header tape is meant to insulate and has a higher level of heat resistance.
I think you should start with the muffler tape because I expect it will be good enough for this.
