Removing PCV and Installing Breather
http://www.c-f-m.com/performancepart...3-LS7-p230.htm
Any advice?
Downfall of doing this? Benefits?
This breather has a one way valve that will not allow air in only out.
Thanks
Any advice?
Thanks
If so just run a catch can on the dirty line, put a one way valve on the clean line (so oil can't get back into the intake from the throttle body), and you can run this breather as well with it since it has a one way out valve.
Thanks for the recommendations
IMO people that don't know any better see what they think is going on race cars is also going to make their mildly modified street car go faster or be better somehow, and that is not always right. Some will research what headers to get for months, and then completely defeat a factory system (like pcv) without even trying to understand it first. "I don't understand it, they don't do it on street outlaws, so it must be bad" type of thing.
In addition, comments like 'it'll be fine' over the internet do not come with a warranty or guarantee (with all due respect).
I also think it is popular to suggest other people mod the way you ('you' being us here in general) mod, in a round about way to make you more comfortable with your own decisions (that's my best Dr. Phil.) I think that is why 'sloppy' builds are so popular.. which truly blows my mind. ''hey look at this slack *** job i did with my car, everybody can be lazy and do it too then it will be 'cool' and I will feel much better about the shitty work I did" Its proven and disappointing.
Properly considered for your application, a pcv system (and a catch can) are be purely beneficial. That's my professional opinion only of course, based on the last 15yrs of r/d.
Downgrading to breathers to me is along the lines of switching from SEFI to carburetors (standard response from any gearhead first time he works on a SEFI vehicle). Think of your response, tell that to yourself about PCV.
Apologies for the partial thread-jack, but I think OP could benefit from this as well.
so you could redo the hoses but just make sure you retain this, that also goes with any catch can you may incorporate to the project.
on newer ls engines this feature is built in to the driver valve cover or the valley plate so some of the schematics you may see floating around may not show one.
MightyMouse, I saw you mention "vacuum regulation." I have your can (can't remember which, it's got the check valve and the breather on the top) with an LS6 valley cover. It's definitely collecting junk, but I recently discovered one of the fittings you provide with the can is a rattle style valve. I had the valley cover (new style I think), your valve and a truck orifice style valve! I eliminated the truck orifice when I realized your valve was there, but can I get rid of your valve if I have an LS6 valley cover? Is that still considered regulated?
I cant really talk about that here, so you will have to email etc. but my advice to anyone with a catch can or pcv system component is to read and follow the manufacturers instructions, and if that still leaves you wondering then please do contact them. you could easily be doing something that is not healthy to the engine.
I've never looked into how this systems works before
