No spark cylinder 6
Old May 22, 2016 | 12:30 PM
Crawling99ls1's Avatar
Default No spark cylinder 6
I'm trying to chase down and figure out the issue of having no spark on cylinder 6 all other cylinders fire cylinder 8 is kinda weak and motor runs ... It's a new built 370 6.0 carb setup I'm running the Daytona smart box system and the representative came to my house and we swapped harnesses and boxes and checked everything from coil swapping and coil harness swapping so it's not there box or my coils I've replaced the cam and crank sensor 3 times with new gm sensors every time now I'm being told it could be the reluctor wheel on the crank as why cylinder 6 has no spark ...
