Home made ram-air.
Old Jun 17, 2004 | 10:00 AM
black_z's Avatar
Default Home made ram-air.
Has anyone made a homemade ramair setup similiar to FTRA, or SSRA? If so do you have a shopping list? I simply cant justify spending 100-180 for it. Ive never seen a setup in person, and cant get a good idea of what is needed from the pictures ive seen. Thanks.
Old Jun 17, 2004 | 06:17 PM
black_z's Avatar
To the top!
Old Jun 17, 2004 | 06:32 PM
Durien's Avatar
i have something a tad different.
i cut the bottom of the airbox then i ran two 2.5" hoses from the front of the car into the radiator....
i trapped at 118 in the 1/4 with just boltons.....i have always wondered if this tubing that i did actually did anything..
Old Jun 17, 2004 | 06:34 PM
Durien's Avatar
if you look under my car this is what you see..this is different than what you are asking ...but its an idea
there are two hoses..
http://members.aol.com/durien512/images/pict0010.jpg
Old Jun 17, 2004 | 06:35 PM
jaberwaki's Avatar
118 just bolt ons!!!!!
was a 50 shot part of the bolt ons?
Old Jun 17, 2004 | 06:38 PM
Durien's Avatar
nope.... totally NA.... yeap 118.25MPH
which makes me the 5th fastest 6psd bolton ls1
Old Jun 17, 2004 | 07:16 PM
jaberwaki's Avatar
race weight?
Old Jun 17, 2004 | 07:20 PM
Durien's Avatar
Originally Posted by jaberwaki
race weight?
around 3420lbs+/- now its heavier...damn roll bar its like 60lbs
i hit 118 4 times... the other 20 something runs were high 117s
all the runs in one day
Old Jun 17, 2004 | 11:45 PM
LS1LT1's Avatar
Lightbulb
I think you were a little lighter than that, maybe closer to 3380 possibly, I think you had Alex's race seat in there too right?
Still damn impressive.
Old Jun 17, 2004 | 11:48 PM
99_1LE_Z's Avatar
I'm going to run a setup similar to what SUX2BU runs
It's been picking up some impressive gains over the FTRA/SSRA style systems too!!!
Old Jun 18, 2004 | 09:48 AM
black_z's Avatar
That is a nice system you rigged up 99_1LE_Z. Thanks for the ideas guys, keep em comin.
Old Jun 18, 2004 | 09:53 AM
SilverGhost's Avatar
Motorboater
i actually got bored last nite and me and my good buddy hope depot did a little messing around
i've got 5 inch diameter piping running from the holes in my grill like the above posted pics up into the airbox, should dump a nice amount of air up there.
Old Jun 18, 2004 | 10:10 AM
NOTFAST's Avatar
99_1LE_Z -- if you could make me one of those pieces for under the filter, I'd buy it...PM ME--i can get the dryer vent hose
Old Jun 18, 2004 | 11:35 AM
99_1LE_Z's Avatar
Just so you know, You'll have to cut the support beam underneath your air box to install the plate, but it can be reinforced. I haven't installed the system on my car yet but will be next month (the pics are of the "inventors" car SUX2BU). I know he was fabbing up some more plates for sale but I'm not sure what he's charging now a days ($40 last I heard). He's on the LS1.com forum usually in the texas members section. I'd shoot him a PM over there and talk to him about it.
Old Jun 18, 2004 | 11:42 AM
99_1LE_Z's Avatar
BTW - He has also matted this system up to TA's as well, I believe going through the fog light openings.
He's seen gains as much of as much as 2 tenths and 4 MPH over other Ram-Air Systems. Going through the front of the car like this will give the most air and the power will climb even higher the faster you go
Beware though as stated earlier the plate and system isn't for someone looking for a simple bolt-on though because you have to cut the support beam underneath the air box and remove the front bumper support to get it to work.
I'm thinking about fabbing up connector to mat a system like this up to any of the cold air systems out there (FTRA, SLP, etc.) so that cutting the support beam would be uneccesary. But Until I or someone else figures that out and markets it, this is probably the best bet
Old Jun 18, 2004 | 03:21 PM
NOTFAST's Avatar
I figured you would have to cut the supports.
Quick question...does the AC condensor get in the way?
Old Jun 18, 2004 | 05:17 PM
jaberwaki's Avatar
that looks great....
when he starts to sell this have him come here and advertize it
Old Jun 18, 2004 | 05:31 PM
99_1LE_Z's Avatar
I don't think the A/C condensor gets in the way.
Old Jun 19, 2004 | 10:37 AM
NOTFAST's Avatar
I think im going to build a set up like this on tuesday, when im off work...
Old Jun 19, 2004 | 10:15 PM
black_z's Avatar
IM gonna try to rig something up very similiar, but I will probably use some smaller tubing in hope of not having to hack the bumper supports out.
