LS6 Alternator Wiring
I have a PSI Conversion Harness and ECU that has the 2 pin plug in to the alternator on it. I then took a 10g wire off the back post of the alt that is ran to the battery +. I had someone tell me I needed to wire in a resistor somewhere in the system or I would kill alternators, but I am not sure if I need it, or if the PSI harness has it. The alt puts out 14.5v - 14.8v at idle so I don't think it is overcharging.
Are there any checks I can do on the harness with a volt meter to make sure everything is working properly before I install the new one? Thanks!
