What is the technical name for this part?
Old Jun 17, 2004 | 05:29 PM
99-LS1-SS's Avatar
STF Veteran
Default What is the technical name for this part?
I have a friend at work with a 99 T/A. This piece coming out of the front of the intake manifold has a hole in it and it is whistling. His car has been running like crap. Is there a way to repair this part or does he have to buy a new one. I explained the part to a guy at a dealerships' parts department and he said that piece was $75. What is the best plan of action? Thanks.
Old Jun 17, 2004 | 05:38 PM
ddelallata's Avatar
have any pics of what you are talking about? just by guessing it could be the PCV hose, or right behind the throttle body is the EGR hose hook up.
Kurt D's Avatar
that's the PCV valve, shouldn't be $75, if it just the neck that has a hole you might try a peice of emissions hose, I think the hole size is 3/4".
Old Jun 17, 2004 | 05:39 PM
ddelallata's Avatar
that's the PCV valve hose
Old Jun 17, 2004 | 05:56 PM
99-LS1-SS's Avatar
STF Veteran
What about a piece of emissions hose with a clamp on it? Is that too much rigging?
Old Jun 17, 2004 | 05:57 PM
99-LS1-SS's Avatar
STF Veteran
The guy at the dealership seemed to think that you had to buy the whole piece that goes back to the back of the engine. Is that true?
Old Jun 17, 2004 | 06:18 PM
MM98's Avatar
Yes that is true... The hose assembly will have the fiitings & pcv valve with it... GM part#12573108.
Mike.
Old Jun 17, 2004 | 07:09 PM
APeteSS's Avatar
you shouldn't need clamps.
the elbow (what you pointed to), PCV valve, and hose are all separate parts. If just the elbow is damaged, replace it, not the PCV valve (which I assume is what the mech. you spoke to thought you were referring to). Shouldn't be 75 bones for a 2 inch rubber hose.
Old Jun 17, 2004 | 11:50 PM
NightHawk's Avatar
Mine got a hole in it too and that's what I did
Old Jun 18, 2004 | 07:30 AM
99-LS1-SS's Avatar
STF Veteran
Thanks guys!
Old Jul 29, 2004 | 06:32 PM
ddelallata's Avatar
does anyone have a part # for this part? Mine tore last week. Or is it even available at the dealer?
Old Jul 29, 2004 | 08:01 PM
badpewter-z's Avatar
LS1TECH Sponsor
you do have to get the whole pcv hose setup they dont sell it seperate but if someone has installed a catch can the probbly have it lying around
Old Jul 29, 2004 | 08:38 PM
Kurt D's Avatar
Or go to Autozone and get a few inches of hose
Old Jul 29, 2004 | 08:59 PM
BLK02WS6's Avatar
3/8" fuel line from any auto parts store
Old Jul 29, 2004 | 09:17 PM
slow's Avatar
www.texas-speed.com
has full 1999-2002 takeoff pcv systems for $15 or so
contact them
Ryan
Old Jul 29, 2004 | 09:32 PM
Another_User's Avatar
All good ideas. But I have a question. What that thing on your throttle cam? The little boxy thing with the cable running through it. I have cruise and traction control, and I don't ever recall having seen anything like that on my throttle body.
Old Jul 29, 2004 | 09:40 PM
LS1TECH Sponsor
you wont see it on your car one is the cruise cable the other is the acc. cable
this car does not have tcs/asr when you have tcs and cruise its controlled by another module on the pass side of the engine compartment, cylinder type shape only one cable goes to throttle body
Old Aug 1, 2004 | 07:12 PM
Strahley's Avatar
At first I thought you were pointing to the throttle cable
