Need advise on broken header bolt under cowl
Already ordered a SS3600.... about to be mid 12's.
If not, I'll try to weld a nut to it. I am basically brand new to welding, so it'll be interesting. From what I have read, and what you've mentioned, sounds like you just really need to get some good globs on there with good penetration and get a nut tacked onto that well....doesn't seem like it needs to be very precise and pretty, so maybe my novice *** can handle it. I'll have to see if I can get up there with the welder that I have though, it is damn tight.
Good luck and keep me posted on how it goes.
So, my plan of the propane torch and the LH drill bit didn't get me anywhere. Looks like I'll be taking a crash course in welding and trying that.
When the bolt first snapped, I noticed the other bosses in the heads and honestly thought about picking up some bar stock to make something almost identical to the product below. Looks like Dorman had the same idea...
It's not listed to work with the LS1, but it works with other LS heads, which leads me to believe it'll work fine. I picked it up for $28 shipped off Amazon and will report back with how it fits later this week:
https://www.amazon.com/Dorman-917-14.../dp/B00OZVPC2G
I really wanted to remove the bolt and have it done "right", but eff it. If this works, it'll save me a bunch of time and grief. Time is at a premium now between work and two ankle biters.
I'm curious how you were able to drill in such a tight spot. Left handed drill was a good idea. I've removed quite a few studs over the years using left handed drills. When I removed the rear most stud on my drivers side, It seemed impossible to drill it out even with an angle drill.
you might get away with copper coating your OEM manifold gasket and torqueing the bolts back down. good luck!
First off - this is a pretty massive and beefy cast piece. I wasn't expecting it to be this robust. I'm impressed.
So, I threw it on the driver's side front of the head as a test fit, since that'd be a mirror image of the passenger rear. Luckily, it fits like a glove - clears everything including the header flange with little room to spare. I am very pleased with how easily it went on and think it'll do the job well.
Only time will tell - I'll get the passenger header on this week and clamp it down.
