Need advise on broken header bolt under cowl
1) Finish my install which includes poly mounts, LT's and Blackheart TD's and hope that it doesn't leak. If it leaks, then I will have to pull the head or remove the header and attempt the nut weld on and possibly remove the head to extract the bolt.
2) Attempt to weld a nut onto the stud. Keep in mind that this is on the rear most bolt on the driver side.
3) Bite the bullet and remove the head and extract the broken bolt and reassemble
4) Bite the BIG bullet and rework the heads. Car has 192K but in exceptional condition and always adult driven and uses little to no oil.
I greatly appreciate any advice on this matter.
And a little more advice. Just drill out the old bolt and retap the hole. I've broken "easy-outs" trying to take out broken header bolts, that is no picnic
A friend is loaning me a 110v welder. I mocked up MIG gun and simulated what it will be like to try to get in there and build up on the bolt. It's doable. I will carefully mask off the rest of the car to protect it from splatter. I'll borrow an auto-darkening hood from work. I'll keep you guys posted. It will be the tightest spot I have ever welded in.
Working on cars really sucks at times.
As it turns out with no header/manifold on, there is a good bit of room to work from undernieth. It's also easier to see due to the angle of the head. Only bad part is the splatter coming down on me. I plan to be well suited up. I hope to tackle this one night this week.
Headers arrive tomorrow. I'm pretty excited.
Lincoln 140 on high with .035 Flux core. Awesome little welder. I went from undernieth after putting rags and wet cardboard on exposed surfaces.
Prepped area photo from welding position
After building up the stud, I held this nut with long nose vise grips and tacked it to the blob. Then welded it.
From the topside after removing some protectiin.
Now don't ever use the GM header bolts again, even new, they will break again. EVERY ls1 engine I've worked on, I've had many, has snapped the factory header bolts on the far ends, either front or rear of heads.
I use ARP bolts, and good quality studs with nut on the each ends of the cylinder heads
