Starting issues after cam swap
Old Jun 18, 2016 | 04:00 PM
jeremygto's Avatar
Default Starting issues after cam swap
Hi,
Just went through a cam, heads, and torque converter swap and now I'm having issues starting the car. It's not tuned yet, but I would expect it to at least start.
The cam is a tsp v3 231/234.644 .598 111
The heads ported 243 63.5cc
As far as I can tell everything was plugged back in. If I'm forgetting some info that could help troubleshoot this issue please let me know.
Here is a link to the video, I couldn't attach it here.
https://plus.google.com/115319138569...ts/QE84FH2XWfs
Old Jun 18, 2016 | 06:28 PM
juniorssrollin's Avatar
Sure timing set is lined up correctly?
Old Jun 18, 2016 | 06:30 PM
jeremygto's Avatar
Yep, the 0 is lined up with the dot. Rotated the motor a few times and the still lined up. Also ran a code check, no errors. I have fuel pressure checking spark now.
Old Jun 18, 2016 | 07:03 PM
jeremygto's Avatar
So checked the spark from my predator tuner and its showing 12.3 not sure if this checks all packs or just the voltage going to the coil packs. I don't have an extra person around to turn it over while grounding the plug.
Old Jun 19, 2016 | 07:18 AM
Old Geezer's Avatar
Showing a tach signal?
BTW, there's a tune/diagnostic forum for these types of issues....
Old Jun 20, 2016 | 12:37 PM
jeremygto's Avatar
Tach signal is good.
I noticed it was the wrong section the next morning after posting. Mods feel free to move.
Old Jun 20, 2016 | 11:15 PM
roth2000's Avatar
Are you getting fuel? I know I pulled my fuel pump fuse to run it dry before I started my swap so maybe double check there???
Old Jun 21, 2016 | 05:09 AM
jeremygto's Avatar
Plenty of fuel a few of the plugs were soaked..
 Michael S. Palmer
Old Jun 21, 2016 | 05:29 AM
Darth_V8r's Avatar
Moderator
Sounds like startup air. If you have HPT you can fix it. If not, hold your pedal down while you start if you can get it to start and warm up it should finally hold idle. You might need to adjust throttle set screw if it's a cable throttle
Old Jun 21, 2016 | 05:33 AM
jeremygto's Avatar
That was the 1st thing I tried. I had that issue with my old car Everytime it was -0 outside.
