How to get CPS Sensor to stop leaking???
Old Jul 6, 2016 | 01:34 PM
02BlkTransAmWS6's Avatar
Default How to get CPS Sensor to stop leaking???
I've changed the sensor twice, and the o-ring on the second sensor twice now. I am still getting enough seepage to drip from the bell housing. I am sure it is the sensor as nothing above it is wet, and the rear main seal is bone dry. The bottom of the sensor has oil on it every time I change it. What have you guys done to seal this up completely?
Old Jul 7, 2016 | 10:06 AM
conan's Avatar
Put a wipe of red Hi-temp RTV silicone around the O ring before you reinstall.
Old Jul 7, 2016 | 12:43 PM
Any worries of some rtv getting loose? I wouldn't go nuts but frankly I was really hoping to not have to resort to rtv. Have you personally used rtv with success?
Old Jul 7, 2016 | 01:12 PM
conan's Avatar
Nothing to worry about, don't use a crazy amount of RTV and you'll be just fine. I've been using RTV in different applications for years and haven't had any issues. Just make sure to take the O ring off the CPS and clean the sensor, engine block, and O ring very well before you apply. Contamination will ruin anything.
