LS1 Factory Temp Sensor Needed????
theres a bolt that plugs the hole where the factory temp sens goes but its stripped. I know i can get a bolt remover kit but that would also mean id have to remove my header because its in the way. basically a huge pain in the *** to do so. I also know theres another hole on the passenger side of the block but that bolt is not wanting to come out and i dont want to strip it. need help!!!!
Also, depending on how the spark timing modifier tables are populated, it will advance spark timing.
Also, it will cause temperature blending to undertemp during heatsoak conditions, causing cylinder airmass to be overcalculated, causing extra fueling and also extra spark timing.
