Wiring harness routing
2000 Z28 body, 2001 LS1
1) on the PCM side where exactly does the harness route around toward the back of the heads? Mine is in, but don't have enough slack to plug up to PCM and connectors along right fender. The smaller harness that goes to starter, etc is wrapped behind/under the right coil pack bracket, but that seems to be causing the problem.
2) where/how do the battery cables route? I was thinking behind (toward front of car) the condenser but wanted to make sure.
Thanks fellas
the starter harness drops down in front of the heater box in between the frame rail and header (wrap with heat tape)
Positive Battery cables route from the battery to the fuse block along the front of the radiator fans to the main positive on the fuse block.. positive runs from battery to starter.. and last positive runs from Alternator to battery
negative runs from starter to negative terminal on battery and other side just grounds to the inner fender near the battery
