Head Bolt Torque Question
Old Aug 31, 2016 | 10:26 AM
SumDumKid's Avatar
Default Head Bolt Torque Question
I installed some ARP connecting rod bolts, and did a 2 step torque sequence, 20# and 40#, broke loose, again, loosened, and then final torque.
Question is, do I do the same with head bolts? ARP bolts, I did my first pass at 25#, 50#, and finally 70#, then torqued the small head bolts. I lost my instruction sheet (pretty sure my dad threw it away).
Also, what is the specific torque for the small head bolts?
Someone please clarify/confirm. Thanks in advance.
Old Aug 31, 2016 | 10:51 AM
kinglt-1's Avatar
ARP head bolts are a 3 step sequence then you are done. The little bolts do not require much at all. I was thinking 15-22ft lbs off the top of my head.
Old Aug 31, 2016 | 12:47 PM
SumDumKid's Avatar
Ok, thanks. That's what I was guessing but I just wanted to make sure.
I just looked on LS1howto and it says 22 ft lbs.
