Knock sensor help needed!
Old Sep 8, 2016 | 08:16 AM
Ruffturbo911's Avatar
Default Knock sensor help needed!
Can somebody please tell me the correct part number for the knock sensor that goes in a 2001 Pontiac Trans Am LS1?
I am getting two different part numbers between AutoZone Amazon and Summit Racing. Is it 12589867 or 213-3521?
Old Sep 8, 2016 | 09:33 AM
67Lark's Avatar
Those are the same part. The 213-3521 is the ACD number and the 12589867 is the GM number.
Old Sep 8, 2016 | 11:43 AM
Thanks. Now debating on whether to use FelPro or GM gaskets.
Old Sep 8, 2016 | 11:53 AM
SlasherVRGR's Avatar
For the intake? I used felpros and they work just the same I'd imagine.
Old Sep 8, 2016 | 12:25 PM
67Lark's Avatar
felpro gm or mahle should all work just fine
Old Sep 8, 2016 | 12:31 PM
98CayenneT/A's Avatar
Fel-Pro works perfect for the intake manifold.
Old Sep 8, 2016 | 05:23 PM
Thanks all. I ordered all the parts and a buddy with an LS3 said he'd help out if I needed help. I think it will work out well and at most I'll just need to buy a torque wrench. Doing all GM parts with FelPro intake gaskets. Hopefully this solves my PO332!
Old Sep 8, 2016 | 06:43 PM
usnfenix's Avatar
replace the harness while you are in there, its only 40 bucks and prob could stand to use it
 Michael S. Palmer
Old Sep 8, 2016 | 08:07 PM
I ordered that too.
Old Sep 9, 2016 | 08:59 PM
Paul Bell's Avatar
That's MISTER MODERATOR
While you're in there, you are doing this much needed mod, right?? http://ls1howto.com/index.php?article=18
Old Sep 10, 2016 | 08:25 AM
No I wasn't going to. Can you just get a modded LS or new LS 6 valley cover without messing with the engine?
Old Sep 10, 2016 | 11:33 AM
Paul Bell's Avatar
No, the LS1 block will need this modification.
HOWEVER, your car may have come with the LS6 block which won't need the mod.
Old Sep 10, 2016 | 11:40 AM
My PCV leads out of the rear of the drivers side valve cover so I think it's an LS1.
Old Sep 10, 2016 | 12:05 PM
Paul Bell's Avatar
This is correct for an F-body, even if it was one of the vehicles that received the LS6 block. The LS1 AND LS6 blocks used in Camaro/Firebird production will always use the Camaro/Firebird LS1 style PCV system.
Regardless, the LS6 PCV mod is a smart upgrade and worth the effort and small cost. If you have a LS1 block, cut out the nub in the block, it's easy. If you have a LS6 block, no cutting needed.
Old Sep 10, 2016 | 12:14 PM
Ok I got you. I thought the 6 block had the vented valley cover. I couldn't see anything with a mirror looking for the 6 block number.
Old Sep 10, 2016 | 12:22 PM
Paul Bell's Avatar
I'm not sure if you've started this project yet but once you pull the valley cover, you'll know. With the estimate of 10~15% of F-bodies getting the LS6 block in 2001, it's unlikely that you have one but there's a chance.
If it were me doing the job, assume it'll need cutting and hope it won't, just to eliminate the one step in the work.
Old Sep 10, 2016 | 12:35 PM
That's a good idea. I'll look for the cutting wheels and ready the shop vac! Too bad the engine is still in the car, otherwise I'd be tempted to do a cam and heads. Not sure if it would pass emission then
Old Aug 29, 2022 | 04:53 AM
Everything works great and valley mod worked out well too. Thanks
