Oil cap breather
2. It is random because there will always be a differential present, and that differential of pressure will generally be at the whim of individual cylinder intake valve pull events and overall engine pressure ratio and resembles wave-like properties, thus you never know what you are "getting" when using intake-driven PCV from one moment to the next. If your car has a 'negligible total amount of flow' due to a restrictive PCV valve or lines/system, that is not ALL cars and it is still random on a small, insignificant scale.
/yawn
By the way,
The correct way to actually answer my original question is that the check valve on the valvecover is closer to the higher point in air pressure differential on an engine running WOT in a N/A application, and is therefore more likely to hold the pressure in the crankcase lower due to it's location than the OEM filtered post maf source will. I guess I know all along too.
Well sort of. The cap breather doesn't catch anything, it wont help anything stay clear of oil, in fact it might even let oil out and spray into the bay. Its not a catch can. Its just a check valve right?
Unmetered air is the least of my concern, forget I even mentioned it.
Vapors out, I understand. Thats a good use for the breather cap, like I mention above. If you draw a picture of an engine at WOT, then draw a picture of the PCV system, complete all the way to maf... Now, fill in the pressure scalar units each. Write them into the picture, where do you think/feel the pressure will look like at each point?
Would you like a picture to describe what I am trying to paint?
http://s9.photobucket.com/user/kingt...v9iza.mp4.html
http://s9.photobucket.com/user/kingt...7m3ni.mp4.html
I have all kinds of car related fun, welding, wiring, ECU assembly/tuning, trans builds, whatever wherever life takes me.
It does in FACT help keep oil out of the intake, ask me how I know...
Instead of the oil vapors traveling up the clean line into the intake under engine braking the pressure is released through the breather. (I also have a 1-way check valve in the clean line).
The filter on the breather will stop any oil from actually coming out, but can get a little soaked in it.
Why are you only talking about WOT? That is the least of my concerns.
2. You should not have check valves on all PCV lines because during intake manifold vacuum the crankcase pressure will go south and pull on the engine oil seals (causing a busted oil seal, rear main, front main, oil pan, etc) This is why the open "clean line" exists. I assume the clean line is the air filter tract, as your terminology is lacking (you say intake but there are two intakes on the car, which one are you referring to? The manifold or air filter intake? )
Seriously, the PCV system for the LS platform and the common methods of fixing its shortcomings are not rocket science here. That valve cover breather combined with a vented or non-vented catch can works perfectly. Tuning for it is a non-issue. Anything else being said is just verbal diarrhea.
2. Ah but it IS rocket science. Everything is rocket science. Even if just because I make it that. When I cook, clean, or modify my car, its always science.
Sorry brother but you're dead wrong. The stock pcv system pulls air from the TB, which is after the maf and the computer can see and account for this. As soon as you open it to atmosphere the computer can no longer see how much and when the air is getting ingested, remember after it goes through the engine its pulled into the intake neck and sent in for combustion. Opening to atmosphere introduces extra air just like an intake leak. Your o2s should catch it to a certain degree but that only works so much when the maf and 02s dont jive. A check valve makes this a non issue but again not all breathers have this.
