Oil cap breather
keep in mind there is an fresh air source tied to the air filter tract that feeds the crank case. This is the metered equivalent of any 2-way breather on the engine, which is why I asked what was the point of the check valve? If we have an intact PCV system , this tube functions to release pressure, exactly like the port that was just added to the oil fill cap... so now he has two I guess. "shrug"
Think of this. The brake booster is "un-metered air". Next time you get into a maf car, pump the brake at the light, watch the wideband go lean. There is always going to be some un metered air in a system like this on an automobile. I was only pointing out that... before he added the breather to the oil cap... the engine already has one that routes the crankcase -> air filter tract. So now he has two. Which is why I says "What da point brah"
The brake system is closed and uses available excess vacuum and provides no source for additional airflow. If you go lean standing on the brakes, you've got blown seals in your booster.
A valve cover breather on a mass airflow car does give the opportunity for extra unmetered air, but only when the PCV valve is open. And it's a tiny percentage of very predictable airflow. It is not random. It will provide the same amount of additional air on a RPM/KPA basis. Any tune will compensate for it without issue. Especially a speed density tune.
Also, the stock system uses a source of filtered, metered air post MAF. There is no unmetered air in a stock system.
Everything you just said is wrong. Again.
