H/C/I Wishlist
1999 Trans Am
TSP LS6 CNC ported head package
w/ PAC .660" dual springs (package option vs .600 beehive)
Titanium retainers, stainless steel valves.
Lunati hydraulic roller lifters
TSP hardened chromoly pushrods
Brian Tooley rocker arm trunion kit
TSP 233/239 .600/.600 112 LSA cam
Oil pump (still debating replacement LS6, Ported LS6, high
pressure Melling 295, or high volume/pressure Melling 296)
LS2 timing chain
FAST 92mm intake
LS6 coolant lines
LS6 valley cover
Nick Williams 92mm throttle body
FAST 36# injectors
Car already has FTRA, lid, LTs, ORY, catback, 3.90 gears. One small bottleneck I see is the LTs being only 1-5/8 instead of 1-7/8, but I'm not too concerned about that at this time.
My uncle has a welder on hand, so also debating dual electric cutouts in the ORY simulating open headers.
Other than that, me graduating from the import crowd and still being a little bit of a ricer at heart, I can be obnoxiously loud on demand with that cam lmao
And yes I understand what you're doing with the dual cutouts here. It will be crazy loud for sure lol
92 is pretty much plug and play.
Honestly, I'll let the tuner handle what it'll eventually spin out to, probably around 6500, but even if it goes that high, I'll most likely never run it that high personally, even just playing around. I don't even redline it as it is now. When I took it to the track, I didn't launch, just rolled into it like from a red light and short shifting around 5400, only ran a 13.3, but I'm fine with that lol
Btw im running Livernois stg 3 Ls6 heads, and TSP 233/239..
You're right. See what the curve looks like & where it's happiest.
