Ls1 f body pump with mech fan
im trying to run a mechanical fan on my ls1 . I have an f body pump and truck pump side by side and the housings look identical. Shaft sticks out the exact same. I'm worried if I swap the threaded pulley over to the f body pump it won't go down far enough to line up with the Camaro accessories . I don't want to run truck accessories. I'm trying to keep everything close to engine as I can since space is limited. Electric fan is not an option. It will not work for my application.
