LS7 water pump compatibility
Old Oct 16, 2016 | 12:09 AM
JimMueller's Avatar
Default LS7 water pump compatibility
I've got a LS3 in my F-body, currently using a LS2 water pump. I was wondering what noticeable performance I'd gain by switching to the LS7 pump. It looks like so far as OEM pump efficiency, LS7>LS3>LS2>LS1.
But the LS7 has a 'flat' pulley, will that work with my F-body accessory drive or would I need to move my LS1 pulley onto the LS7 pump? If I lose the benefits of the reduced mass pulley I might not be interested.
Old Oct 17, 2016 | 06:50 AM
Undertow74's Avatar
There would be no difference, and you would have to swap the pulley out to the bell shaped pulley
Old Jan 7, 2018 | 06:09 PM
Smizx7's Avatar
How does one switch the pulley out?
Old Jan 16, 2018 | 05:10 PM
ss.slp.ls1's Avatar
I would just stick with the pump you have if you are not having any cooling issues. As far as performance gained from pump efficiency, I doubt it would be noticeable compared to other performance mods. I wouldn't swap pumps unless you are going with an electric pump...even then the difference is not very much.
Old Jan 16, 2018 | 05:12 PM
LLLosingit's Avatar
I found out it's not easy to do, Basically you're rebuilding the pump to swap pulleys.
