243heads/ls6 set up
Local guy in the area is setting 243 heads with valves and springs off a TBSS (65k) ls6 manifold slightly ported and bbk 80mm tb and ls1 rails with fuel injectors for 1400CAD.
I am planning on offering him 1000CAD flat for the whole set up, if he does not take it I will subtract the bbk80mm as I've read it isn't really worth it and I can just port my stock one and I will also subtract the rails.
Hopefully he takes 1000 for the intake and heads, if not I will just go for the heads alone which I really want but just trying my luck to get the whole set up... why not right?
does this sound like a good idea?
Or should I just buy the whole set up .
