78 vs 85 throttle body...
Old Oct 20, 2016 | 08:54 PM
wannafbody's Avatar
Default 78 vs 85 throttle body...
Which do you prefer? Seems to me that the 78 has a slight bit more throttle response off idle but the 85 probably provides a bit more HP up top.
Old Oct 21, 2016 | 08:58 AM
Aaron at SDPC's Avatar
What is the application? What are the other mods? In my experience just simply swapping from the factory 78mm throttle body on a stock intake to an aftermarket 85mm isn't worth much at all.
Old Oct 21, 2016 | 09:02 AM
wannafbody's Avatar
2000 LS1, BBK intake on 853 heads, stock cam
Old Oct 21, 2016 | 09:17 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Save up time to research real mods. So far what you have mentioned is not noticeable for better or worse.
Old Oct 22, 2016 | 11:15 AM
wannafbody's Avatar
Well, it's a noticeable improvement over the stock LS1 intake
