What timing chain, and lifters?
Thanks.
The block mounted timing chain snubber (black) will fit that chain.
The L-92 VVT is the best chain Idler and MUST be modified for HP use by changing the tension spring.
Need more information for lifters, valve weight, lift, spring tension, RPM ?
Lance
The "boost" pressure effects Valve Train design. (valve seat pressure)
What will be your max boost ?
My spring choice would be a "dual" for the turbo.
This spring design features high seat pressure with low nose pressure.
We then fit Ti-Retainers on intake valve ONLY.
The turbo needs an increase in oil pump capacity.
The common choice is 2010 Camaro though a GM HV pump could be required when TWO turbos are fitted.
Will you fit one or two turbochargers.
A coil output increase will help with either choice and fuel use be reduced when a high output coil is fitted.
Lance
Your 6500 RPM = 20ms@6000 RPM of injector frequency = OK
Your Fuel Pressure (?) is a common rating of 45 psi. = OK
Your BSFC also effects injector sizing, turbo = .5 is common = OK
Your fuel's specific gravity AND "E" content (?) pump grade is .790 = OK
The stated # 42.lbs x .5 BSFC x 8 injectors = 672 HP 100% Duty Cycle.
NOW "de-rate" the HP for the 80% Duty Cycle often specified = 596 HP
Thus a "street" rating of the 42's is 550 HP.
I also agree that the requirement for at least a 62 lbs (650cc) is WELL stated.
The manufacturer is use is Denso due to SMALL fuel droplet size with a result of a higher BSFC ability.
Lance
