5.3 differences
Old Oct 27, 2016 | 04:20 PM
cbra-klla's Avatar
Default 5.3 differences
How much difference in strength is tbere between the gen3 and 4 5.3? I've tried searching this on here but really can't get any true facts
Old Oct 27, 2016 | 04:38 PM
EddieGoesFast's Avatar
Keep the RPM's under 6600RPM for both and I'm going to say about 250 HP difference in strength holding capacity.
Eddie
Old Oct 28, 2016 | 10:33 AM
ls1charged's Avatar
i just picked up a gen 4, the rods are very noticeably beefier!
Old Oct 29, 2016 | 09:03 AM
pantera_efi's Avatar
Default GEN-III/GEN-IV block strength
MY observation :
1. The block that has two different length "long" head bolts is weaker as stated by GM.
2. The block that has a breather "hole" between the main/cam tunnel is VERY weak AND will crack in that area.
3. The boss area needed to fit a Timing Chain "Idler" is not on many early blocks that when fitted will GREATLY increase chain life after being installed.
Lance
Old Oct 31, 2016 | 07:11 AM
ls1charged's Avatar
Originally Posted by Pantera EFI
MY observation :
Lance
so are you referring to the gen III or IV as being weaker? because ive yet to hear of either of your first 2 points about a Gen IV
Old Oct 31, 2016 | 07:21 AM
JoeNova's Avatar
Restricted User
Eddie
I'd say closer to 400.
Old Oct 31, 2016 | 09:06 AM
ls1charged's Avatar
considering the gen 3 has proven to take so much abuse already, thats very encouraging for the fact that i just bought a Gen4 lol
Old Oct 31, 2016 | 09:10 AM
JoeNova's Avatar
Restricted User
Someone just broke the stock bottom end chassis dyno record in the last few days. 11xx whp on a stock 5.3. Its already proven itself in the quarter mile laying down lots of low-mid 8s.
 Michael S. Palmer
Old Nov 3, 2016 | 05:47 PM
cbra-klla's Avatar
So are all gen 4 motors have the 54x reluctor? Do you have to run a lingenfelter box to convert a gen 4 in an fbody?
Old Nov 3, 2016 | 11:48 PM
ls1charged's Avatar
i believe ls2's and the lq motors still have the 24x wheel, other wise you either change the wheels or get the LPE converter like you mentioned
