Help ID'ing a sensor
Old Jan 8, 2017 | 06:07 PM
volsfan32119's Avatar
Default Help ID'ing a sensor
I'm getting ready to pull my LS1 and I took off the valley cover to put the lift plate on. The plate is too long in the rear so I need to remove two sensor/sending units on the top rear of the block. One I'm pretty sure is oil pressure and it just screws out. The other has a 10mm bolt securing it but when I took the bolt out the thing doesn't just pull up like I thought it would. I didn't want to break it by forcing anything. Can someone please tell me what it is and how to get it out?
Old Jan 8, 2017 | 06:48 PM
Soooooo I'll answer my own question. It's the cam shaft position sensor and it just gets pryed out.
