coolant level -- sensor info.
Old Jun 27, 2004 | 06:05 PM
cheez22's Avatar
Damn, mine just came on too! My coolant is full too. I guess I'll unplug it.
Old Jun 27, 2004 | 06:52 PM
JimMueller's Avatar
Originally Posted by WILWAXU
2000-2002 cars don't have that sensor
But my 98 has a working ECT sensor
My coolant level sensor is dead, too. Just like others have done, I disconnected it and I check the level manually.
Old Aug 3, 2004 | 12:02 AM
phat-ss's Avatar
i replaced my sensor does the same damn thing , i seriously doubt i got a bad replacemnet sensor but i have no clue why my light comes on , only when it warms up a bit checked level cold checked it hot always good//
Old Aug 4, 2004 | 09:36 PM
ddelallata's Avatar
I had the Low Coolant Level light come on today and upon inspection , the coolant level was fine. I cleaned off the metal rod on the sensor with a Q-tip and the light turned off. Lucky me. Thanks to those who posted about this quick fix.
Old Aug 4, 2004 | 11:43 PM
EdmontonSS's Avatar
I used C.L.R. (Calcium Lime Rust) cleaner on my sensor, worked great. Bought car used, light came on soon after, it's been off for over 2 years now. I believe there was a wire retainer holding the sensor in?
Old Aug 5, 2004 | 01:16 AM
MeanWS6's Avatar
Its very common on 99's
I just removed mine, it was a pain dealing with it all of the time
Old Sep 8, 2004 | 02:27 PM
ramairbrc's Avatar
Mine came on last week. It is not "on all the time." What I mean to say is, after I start the car it takes about 5 to 10 minutes before it comes on. IS that the same problem the rest of you are having, or is your light on from the moment you start your car?
Thanks. Bob
Old Sep 8, 2004 | 03:45 PM
phat-ss's Avatar
I fixed mine, wasnt the sensor , rarely is from what i hear I got a huge funnel and placed in radiator started car and let it get hot and a couple heat cycles (fans kicking in ) and made sure it was topped off if any air trapped in system makes that sensor trigger , but mine would come on after 10 mins or so since i did that trick with big funnel to let it boil into have had zero issues
Old Sep 9, 2004 | 12:42 PM
Nick D's Avatar
Mine comes on at startup when the car is cold. If I get to a stoplight when I am up to temp and turn the car off and on, the light doesn't come on. Also, if I drive on the freeway, with the light off, it will suddenly turn on after about 50 minutes of driving. GM could have designed this headache better.
Old Sep 9, 2004 | 01:38 PM
phat-ss's Avatar
Yeah agreed , but thats why the quit having them after 99 . 2000 + cars eliminated it
good luck
Old Sep 10, 2004 | 12:48 PM
ramairbrc's Avatar
Thanks. But I'm not sure I really understand what you did.
1) removed cap and placed large funnel in radiator
2) started car and allowed to hear up
3) topped off level in radiator with car running
4) removed funnel and replaced cap
That's it?
Old Mar 11, 2005 | 05:11 AM
  #32
tattooZ's Avatar
Default ???
That's it?
My '99 Z is doin the exact same thing. I would like this 'big funnel' trick explained a little better. I'd like to try it.
Old Mar 11, 2005 | 07:10 AM
  #33
texada's Avatar
My light came on this morning, where exactly the sensor is located?
Old Mar 11, 2005 | 02:31 PM
  #34
ddelallata's Avatar
on the passenger side of the radiator a couple of incles below the radiator cap. There is a wire clip that you have to remove to remove the sensor. no big deal.
Old Jun 18, 2010 | 03:33 PM
  #35
99YENKO's Avatar
I have a 99 and when i unplugged my ECT the light stayed on..
