TBSS intake on 03 4.8
Old Jan 9, 2017 | 10:29 AM
20Silverado03's Avatar
Default TBSS intake on 03 4.8
There is a TBSS intake for sale complete with rails and injectors, would this be a bolt on?
I know a lot of guys have to change some things since they buy just the intake but if its the complete factory set up should it work?
Old Jan 9, 2017 | 10:30 AM
JoeNova's Avatar
Restricted User
Bolts right on. You might have to change a couple of things to work right with it though.
Old Jan 9, 2017 | 10:34 AM
SQRBODYLSFREEK's Avatar
Correct me if I am wrong but... doesn't the truck intake flow better??
JoeNova's Avatar
Restricted User
TBSS/New style truck intake flows much better than the old one.
Old Jan 9, 2017 | 10:52 AM
the tbss intake is returnless but my truck is return style? help!
Old Jan 9, 2017 | 11:38 AM
ive heard of using a corvette fpr/filter. where would this specifically be installed? what would be needed? is there a write up for it somewhere?
Old Jan 9, 2017 | 12:17 PM
Novapat67's Avatar
I've been doing research to swap this same intake onto my 06 5.3l. Here is what I found. Feel free to correct me if there are other options!
DBC
-Need an aftermarket 90mm throttle body
DBW
-Use TBSS TB with X-link($240)
OR
-Use silver blade LS2 TB with matching pedal and TAC
You will need to adapt your fuel system depending on what you have. Best of Luck!
Old Jan 9, 2017 | 12:35 PM
JoeNova's Avatar
Restricted User
Or you can use an adapter and your stock gen 3 DBW TB.
Old Jan 9, 2017 | 01:03 PM
So would i need an x-link for the ls2 silverblade tb?
Joe, how much is the adapter for the stock tb?
What does TAC mean?? what do u by pedal? gas pedal???
Old Jan 9, 2017 | 01:19 PM
JoeNova's Avatar
Restricted User
Adapters are literally all over the place. You shouldn't have the slightest bit of trouble finding one.
Old Jan 9, 2017 | 01:26 PM
bigdaddy350's Avatar
TAC is the computer that controlls the DBW system. You would need the correct electronic gas pedal to use the DBW
Old Jan 9, 2017 | 01:44 PM
im already dbw, would i need a diff tac and pedal anyways?
Old Jan 9, 2017 | 01:45 PM
if i get the tb with the tbss intake ill get the x-link else ill get my tb ported and get an adapter if the adapter is cheap
ls2 tb seems like a lot of work
Old Jan 9, 2017 | 06:45 PM
Novapat67's Avatar
It would be interesting to see what kind of gains you would get with a 78mm throttle body on a tbss intake. Even with heavy porting I feel like it would be a big restriction. At that point, I would wonder if you really gained much over the stock setup. But then again, I've never tried it. What do you think Joe?
Old Jan 9, 2017 | 09:33 PM
i heard ported and polished CAI adds at least 100rwhp
Old Jan 9, 2017 | 09:44 PM
Novapat67's Avatar
At least!!!!
Old Jan 9, 2017 | 10:40 PM
Originally Posted by Novapat67
At least!!!!
If you have Pat G spec your CAI that is
Old Jan 11, 2017 | 05:23 AM
gagliano7's Avatar
http://www.performancetrucks.net/for...-493269/page2/
http://www.performancetrucks.net/for...9-02-a-459296/
