Thermostat problem
Old Jan 17, 2017 | 08:46 AM
Nali6.2's Avatar
Default Thermostat problem
So im i have a little bit of a problem on my 5.3 i have an fbody water pump on it and i went to get a tstat for it and i obviously got the wrong one. I found out the correct one for this pump is built into the neck. I have a cnc housing i would like to use because i have -20 coolant hoses and want it to point out straight. Which tstat would i be able to use?
Old Jan 17, 2017 | 10:00 AM
98_WS6_M6's Avatar
Could you just use a meziere inline thermostat housing with that t stat you have there?
https://www.meziere.com/Products/Coo...1-50-Hose.aspx
Something like this? They have a few different types. It's what I used with a race style meziere pump where the t stat doesn't attach to the water pump housing. I don't know how you want to run the lines but hope that helps.
