Help, neutral safety switch wiring
ECU pin 34 is for neutral safety switch signal, correct?
If so, is this how I should wire the setup...
Ignition switch in on position will provide power to neutral safety switch. If, transmission is in Park/Neutral the power from ignition switch goes to starter solenoid and pin 34?
Is that correct?
ignition switch in the start position sends power through the neutral safety switch to solenoid. My current piggybacked wire to the pcm only gets power during the starting phase. Assuming that is true the rest of the time that wire should have no signal to pcm.
Hrm....
red wire goes to original harness to flasher fuse.
green wire goes to back up lights
purple/white wire went to starter solenoid
purple wire goes to ignition switch.
Pin 34 was piggybacked on the purple wire going to the ignition switch
If that is the way it was before then try it.
